Octy vrs mk1 piper exhaust
wheres the best place to purchase one of these pipes as i need one in my life like now lol needs to be piper tho ideas please !
Venom Motorsport?
W8 on here can supply I can but rob is main dealer on this forum for piper
IIRC UNIT18 are a Piper retailer
ebay one`s more than venom so i think ill order that
eBay I got mine off terkin sounds awsome with decat
Piper catback non-resonated on mine, sounds the nutts. Not too loud, nice burble on tickover, roars when pushing,  well recommended :thumbup:
Agreed I love mine also. Twin pipes, just the look I wanted and sounds lovely when on the power but civilised when cruising.
thanks mate dont want cat tho i want oval 4 inch
I have that one :) J3 style
Edited by mluton
he is selling that stuff over priced imo
same as mine looks great
yep that's the one .... :rock:
just needs a tad raising on mine as i would like it to sit closer to bumper
Are exhausts hard to fit yourself? (All I have is a jack/axel stands)
You'd need to get the car as high as possible to get to everything. And if you're removing the stock exhaust you'll need a method of cutting it as it's one piece.
ah damn, probably cant do it myself then. :(
Not to difficult did all mine, need to get car as high as possible. Especially if replacing front downpipe/cat.
However a lot easier if a Garage does it
As Rob states the stock exhaust is one piece from cat to back box, and was fitted before rear beam, so you will have to cut/angle grind the back section off.
I did a few pics of this somewhere
Yeah, absolutely no chance I am going to attempt grinding/cutting.  :giggle:
You could just drop the rear beam out on the left and loosen it on the right and pull the system past it, but I couldn't be bothered when I fitted mine and just cut the stock system off, but I cut it on a straight part just before the beam so that it could be refitted later with a sleeve.
