Drive shaft problem
I hit a prob I need to fit a new cv joint boot and I have undone the hub nut put my pullers on to push the drive shaft out off the hub and I broke my pullers and the drive shaft is well jammed in the hub any people can past any ideas of how I can remove it I have used the club hammer and little metal bar route and it still don't want to come out it look very rusty too any help would be very great flu or do I have to buy a new hub and drive shaft
Any help would be very helpful
Have you removed the balljoint from the knuckle or the balljoint to wishbone bolts?
Both have been removed it like it's been welded in this car I sort one problem then it kick me in the ass but I will not give up
Edited by TMB
Cheers tmb I will try that finger crossed
Get someone to pull the hub out towards you and use a small drift and a hammer to tap it out. Most come out quite easily with a bit of persuasion.
They rust in to the splines, you may be ok with a hot air gun and get it as hot as possible then a big 3 leg puller on the hub . Sometimes we have needed to remove the hub with shaft and use the 20 ton press to separate them. Use an old hacksaw blade to clean the splines in the hub afterwards.
Spray loads of wd40 on it, get some one to pull the hub outwards and hit it with a hammer
WD40 is pretty useless in such cases. Use a dismantling fluid such as PlusGas. Any good motor factor such as Euro Car Parts will have it.
I used a full can off plus gas and hit it and everything so I have now brought a new cv joint and I just got to get a hub will any hub off a MK 1 fabia fit my sdi
