01336 - Can bus in single wire operation
Hi all this is one of the error codes found using VCDS lite yesterday, how is this fixed?
01336 - Data Bus for Comfort System: Single-Wire Operation Possible Symptoms
  • Data Bus Comfort working in Single-Wire Mode
Possible Causes
  • Wiring/Connectors from/to Control Modules
  • Control Module in CAN Data Bus Comfort faulty
Possible Solutions
  • Check Measuring Value Blocks (MVB)
  • Check Wiring/Connectors from/to Control Modules
Special Notes
  • When found in VW Passat (3B): Comfort System, check Comfort Control Module and Door Control Modules.
    • Wiring/Connectors from/to Door Control Modules faulty
    • Door Control Modules faulty
    • Comfort Control Modules flooded/faulty
It is fixed by finding the break in the CAN-Bus wiring. CAN-Bus wiring is made up of a twisted pair of wires to improve noise immunity. Your CAN-Bus is operating in a degraded state as one wire is broken. You need to look at the orange/green, orange/brown twisted pair.
Where does the can bus wiring run to? I assume it will run from the ECU but then where too?
It's the convenience CAN-Bus that has the problem - not the drive CAN-Bus. Start at the dash insert and follow that pair of wires.
You don't give the year/engine (I assumed BBZ), but the door modules will all be on this bus.
  • 6 years later...
It presumably is a break between the A pillar and door
