How To: Fit Poly Bush Top Mounts
Well fitted the Poly bush top mounts.
Folks who know the Ploy bush top mount realise that the std VRS top mount cup will sit high. Although this does not cause a real issue it could cause strut to drop over bumps and also don't look nice.
Anyway more on that bit lower down i did just drive car and kept the VRS top plates and 3 days of running and i have to say no issue.
The drive with poly bushes is a little better for me because i benefit from the extra shock travel from raising the coilovers to compensate for the 10mm reduced height of the poly bush and something i really needed for my low stance.
No squeaking so far (although did grease them well)
I like the overall feel of the front end with the poly bushes in and i think completes my set up well of complete poly bushed front end and LCR subframe set up with upper /lower braces.
few pics
new bush
I managed to lower coilover down in inner wing with enough gap to remove old Top mount and bearing and refit poly top mount bearing with strut still attached to hub(made life easy) and did not even need spring compressors(shows how low mine is..lol)
New Bearing installed into bush
strut passed back up thought suspension turret
Although i have been driving ok like it bugged me to see the std top plate sitting proud(anyone who knows me knows how fussy i am..lol)
Here is the std top plate sitting high
So today I picked up some VW polo top plates
In actual fact what i also discovered is 2 issues with the polo top mount cup plate
1. It is smaller diameter to the Skoda OEM one. Which could lead to the cup being pulled through turret and some examples seen on over forums
2. It is actually too smaller depth to reach the inner nut. And thus folks could actually attempt to tighten the cup down too much and this will cause bending and probably the cause of item 1 happening.
So what I ended up doing is the following and seen on a few other forums
Cut STD skoda plate to act as a larger washer to turrent
Fit the original Skoda rubber seal over both plates
Then I packed out the gap between strut top mount and bracket with a few washers to build up the height to make the polo bracket touch the washers and sit on turret at the same point as best as can. This allowed for a uniformed tightening and made sure polo bracket could not bend downwards and also ensure the bearing works as normal
weather this messing about is all worth it compared to real results for the poly bush is debatable but made me feel better   :rofl:
I like the results   :thumbup:
nice job mate :)
deffo on the to-do list over the next few months :) (once i get a decent spell off work!)
  • 4 months later...
Have u a part number for the polo cup mate ?
And a idea of how many washers u used to pack it out ?
Is it 2x 6N0412319 mate
Hi dude as a alternative to Poly bush top mounts you could use both the Polo Top hat plus the Polo top mount as that would give you 10mm drop as well.
P/N's
two x   6N0412319 = £9.10
two x   6N0412331A = £15.54
Example of these verses the VRS ones
before fitting Polo Bushes
After
Cool :)
I shall start collecting but
Caps
Bearing
And the poly bush things
Then try be brave once again lol
Your car has changed colour in those last pics mark :D
Lol....
Yeah you don't miss a thing.....[emoji12]
  • 5 months later...
Undo drop link from coilover :D
  • 8 months later...
Hi Bowders,
fixed the new top shocker bush mount in my skoda rapid,I am worried because top mount cup plate sits little high, which is annoying me..
you can guide me is this really a serious problem, causing improper brakes etc..
please reply on urgent basis
Edited by VM3004
