Fitting Milltek DP to standard system
As above what do I need to buy? Reducers clamps etc. All guidance greatly received :-)
If you find out the outer diameters of the two pipes you want to join, you can get an appropriate joiner. Then just use that to slot them together with a couple of exhaust clamps and job's a goodun :thumbup:
You would probably need reducer pipe as d/pipe will be larger diameter than std exhaust, then it is a case of some clamps to hold reducer in place.
Some times the d/pipe will come with a sleeve or reducer  so difficult to tell until you get the parts and then also measure some of the bits.
I have a spare std system so i could measure the diameter .which i think maybe 2 or 2.25 inches but you need to measure your d/pipe to be sure.
Having to get a cat back system now as my backbox sheared off....Milltek 3 week lead time. Therefore Jetex being fitted on Monday :-)
