Removal of Instrument Cluster
Have Fabia Mk1 and a sound like something rolling around below instrument cluster. Removed two screws at base of cluster but unable to remove cluster.
I can only move bottom of cluster about 1/8 inch.
Haynes tells us to tip the top of the cluster forward and remove the cluster, but I cannot get a grip on the top of the cluster to do that.
Does any experts out there have any experience of removing the cluster?
Any information gratefully received.
I have the Ibiza tdi which I'd imagine has a similar design and when I removed mine it was fixed by two screws at the top ( located vertically and easy to get at)and two screws at the bottom which can be seen after removing the trim around the I intrument cluster.
You will then be able to pull it out enough to then detach the electrical cables.
It's a bit of a fiddle but easy after you've done it a few times.
Good luck !
You need to try and wriggle the top part free. An old credit card or similar can be slid in there to help
I must confess some scepticism a credit card would help, but tried it anyway. I found that if I used two, one each side where the cluster curves down, they gave sufficient clearance to get my fingers on the top of the cluster and pull forward.
Many thanks to all.
