VRS FARB
Do all the Fabia's share the same FARB regardless of the platform e.g 1.2, 1.4, 1.9tdi etc?
Nope, VRS one is thickest but IDK about t'others.
Ah I see. Thanks for confirming pal
vrs has a 19mm bar.
Vrs is 19mm, 1.9 pd100 and 2.0(i think) are 18mm. Then theres a 16mm one aswell.
Sent using Tapatalk, like a bawsss!
The powder coating on the farb has worn away and the bar is a tad loose now because of this. If I replace the bushes with the smaller size would this work? Rather than replacing the whole bar? Or is there a workaround for this?
