Fabia vrs Lost power please help me
Hi
I have a problem with my Fabia vrs 2005 Mileage 55k lost power and enter into Safe Mode
vag shows  fault code
17675 P1267
17672 P1264
17965 P1557
and mixed sometimes it is one injector sometimes two and sometimes all 4
Please Help me I replaced the injector wiring , air flow meter ,turbo pressure sensor , fuel filter, air filter , I cleaned the EGR
and nothing on the same, drive  2500-3000 enter into Safe Mode
I did log I do not know how well
first 3000/min Engine speed no drive
http://vaglog.rtnet.pl/turbo23_165767.html
http://vaglog.rtnet.pl/turbo23_165768.html
http://vaglog.rtnet.pl/turbo23_165769.html
http://vaglog.rtnet.pl/turbo23_165770.html
http://vaglog.rtnet.pl/turbo23_165771.html
http://vaglog.rtnet.pl/turbo23_165772.html
http://vaglog.rtnet.pl/turbo23_165773.html
http://vaglog.rtnet.pl/turbo23_165774.html
http://vaglog.rtnet.pl/turbo23_165775.html
http://vaglog.rtnet.pl/turbo23_165776.html
http://vaglog.rtnet.pl/turbo23_165777.html
next 900/min Engine speed no drive
http://vaglog.rtnet.pl/turbo23_165778.html
http://vaglog.rtnet.pl/turbo23_165779.html
http://vaglog.rtnet.pl/turbo23_165780.html
http://vaglog.rtnet.pl/turbo23_165781.html
http://vaglog.rtnet.pl/turbo23_165782.html
http://vaglog.rtnet.pl/turbo23_165783.html
http://vaglog.rtnet.pl/turbo23_165784.html
http://vaglog.rtnet.pl/turbo23_165785.html
Thanks for any help
17965 is overboost. Once overboosting for about 4-5 seconds it will go into limp mode. Hence no power.
Had it in my golf usually down to sticky VNT in the turbo. Check the actuator on the turbo moves - if not then you will need the turbo cleaning out. If it does move, perhaps the vacuum isn't able to move it due to a split in the vacuum tubing going to the actuator or a split diaphragm
I checked turbo  it works well (open and close )
