White smoke (diesel)
On tick over loads of white smoke and juddering, smells like diesel, I have drive the car for around 10 mile back from when it happend, over 2000 rpm it drives as it shud do pulls the same, could it be an injector stuck open
what colour is your oil?
Oil is black, no water in it, smoke smells like diesel, think it's possible an injector stuck open.
you might possibly need a pressure test, could be possible water's getting in somewhere via the head gasket.
Check the water and oil levels beforehand.
Oil and water is ok, the smell of the smoke is the same as when you pull the compression leaver on a diesel generator to cut it out, this is y I think it is a injector staying open
Hopefully a scan with VCDS or similar will throw up a fault in that case so a scan at the least.
