Rear Window Washer..
What fuse/fuse number controls the Rear-screen Washer Spray "not the rear-screen wiper", the front washer sprays water OK but the rear one doesn't, I've checked the Owners Handbook but can't find any reference to the rear washer spray, does it double-up with any other fuse.....
mick
I had this problem couple if weeks back mick, found that the pump was engaging but no spray, checked the hoses all in tacked so I got a small pin and pushed it through the hole found that it was blocked 3-4 times doing this eventually shifted the dirt still don't know how it got in there. Hope this helps
Sent from my GT-I9505 using Tapatalk
Thanks, the pump is working "I can hear it operating, so not a fuse" I should have checked the holes, will try later today.......
Common problem.  Squeese and lift the drive end of your wiper arm and you will see the 2 jets, this just pulls off. operate the rear wash and you should get a stream of wash squirting in the air, this will clear the pipe of any debris Clean the jets and replace. You might need to adjust the jet direction with a pin.
Thanks rlp, job done, easy when you know how, pain in the butt when you don't............just got to adjust the jet so it doesn't spray pedestrians........
