airbag slip ring
Morning all
i have recently had a steering rack fitted on my octy 2001 4x4 turbo. since the steering feels like is resticted behind the cowling at back of steering wheel.
i think this may be the airbag slip ring has been broken? is this possible? anyone know if the part is different on the 4x4 because of ESP?  any one know correct part number and would it be likly i need to replace ribbon too?
whats best plan of action take steering wheel off and have a proper look?
thanks in advance
Have you doubled checked the knuckle joint down on the floor where the steering column goes through the bulkhead ?
This has to be disconnected to change the steering rack
Don't see why the airbag slip ring should have been effected by a steering rack change
the knuckle seems fine. i let my lad in car while it was disconected and erm he pretending to drive.  nascar style left only over and over?
+1
Don't have to take wheel off so would not think issue at top end of steering column.
lol. That should not matter if the wheel was connected to knuckle joint when wheel was correct and centralised should be no issue
Ah...,Was steering column pushed too far down on the knuckle and tightened? Should not be able to do that as bolt will hold it where it needs to be.
Was the rack new or second hand. Maybe a damaged steering track rod?
its a recon rack. bolt to connect to column will only go in one spot due to the notch on the racks spline. can hear squeeking from right behind steering wheel like rubber on plastic. not sure what exactly whats behind steering wheel.
Basically not much
There is no airbag slipring ring as such
The airbag connector and horn wiring come through a connector, and the wheel fits onto a spline
All held in place by a large central nut
This is insided the steering wheel with airbag removed
If the steering wheel/column had moved while the rack was being replaced, it would break it. The slip ring/squib can only rotate a certain about, so if this wasn't centralised with the new rack it could easily break it
Sent with Tapatalk
The airbag connector fits round the column, but doesn't touch it - turned via the plug & pins
Wonder if the wires inside the connector (squib) have been ripped out
Does the horn work ?
Edited by snow_muncher
Basically not much
Well there is the slip ring that go between column and wheel.
That is what allows permanent connectivity between airbag, horn and other display / steering wheel functions
That is what that yellow plug connects to.
getting senile ;)
Was thinking in terms of vw old style steering wheels where the slip rings where built into the back of the steering wheel - a little bit of fluff or grit could create symptons like the op's
Its a separate unit now - all the copper rings hidden away (if thats what inside connector)
Sent with Tapatalk
Horn is working but esp button not working i do think it was turned too far when detached from rack. dont look too bad to remove the wheel
it does feel like twisted wires kinda thing?
You didn't mention the ESP light :rofl:
Luckily both the airbag connector and steering angle sensors are cheap 2nd off ebay
Make sure the steering angle sensor is same or compatible with what you've got fitted
esp squib
The steering anlge sensor is a little box attached to the side of the column
that looks like it mr muncher :happy:  :rock:    watched it again certainly looks like what may be broken
so i need to replace the (slip ring)squib which is same across mk4 etc?
cant get my head around how its all fitted together and what exactly i need?  obviously would like correct parts before i stip it down :sweat:
Edited by ABEB1
getting senile ;)
I know what you mean . I left a dam spanner still attached to the ARB drop link at suspension strut :giggle:  Only found it the only day when doing something else(2 months later)
That is possible your issue as those are fragile and easy to damage. They are meant to be kept dead straight as removed , Any turning or over turning more than the typical steering rack rotation  could cause damage
The one in the vid above is square-ish in shape, then there's a round shaped unit
I'd take the wheel apart and see what you've got fitted
Access to a current version of ETKA would give you a complete list of compatible units
Not sure the cars without ESP have a steering angle sensor
