Oil leak
Any common places were this oil could be leaking from it coming from the rear at the top thanks ash
Can't see a lot in your pic.
is it coming from higher than the head gasket? If so it will prob be cam cover gasket.
could also be from turbo oil feed though.
get it all washed off properly is easiest way to then find it :)
No think your right with rocker cover gasket doesn't really use much oil thanks ash
