Bulb Upgrades on 2014 Fabia vRS
Been doing some reading and just after some further advice please.
Am I correct in thinking that the headlight bulbs are a H7 fit? If yes will the below be OK?
http://www.ebay.co.uk/itm/251442852442?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2556wt_1399
Or
http://www.ebay.co.uk/itm/350956377044?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Or dare I risk the below.
http://www.ebay.co.uk/itm/310894618369?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Also looking to replace the std carrot indicator bulb but not sure or pin fit (not taken one out yet). Are they stright or offest fit? Will the below be OK for front and rear?
http://www.ebay.co.uk/itm/330381037221?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1779wt_1399
Or will the Philips be a better bet?
http://www.ebay.co.uk/itm/350774654599?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2890wt_1161
Last bit of advice please. What fitment are the interior bulbs as I want to upgrade to LED. Are they 501?
Cheers,
Phil.
Hi
Yes, headlights are h7. People on here tend to go with either Phillips or Osrams, the night breakers.
The blue bulbs will almost certainly give off less light than other bulbs.
I have the cheaper silver vision off set pin indicator bulbs in mine, had them in a year with no issues
Interior is 2x 501 and 1x 42mm festoon. Make sure the 501s are stubby and short or cover won't go back on.
Sent from my GT-N7105 using Tapatalk
Cheers bud. On the case as we speak.
Hi
Any links to what you have used for the interior please?
Hi
That is the wrong bulb for the boot, the boot is also a 501.
The ones you have linked from eBay are the right ones for the interior, I will try and find some links after work but they are as good as any.
The festoon bulb you linked will fit the interior dome
Hi
Thanks.
