Octavia sound system????
Hi,
I have new octavia combi TDI 2006(made after 07/2005 when model year changed) and I have audience player on board. Now i
I don't believe that an aux connection is available on the audience. The new Stream Head Units have one which can be turned on through the menu. If this aux option isn't on your menu then you don't have it. I doubt it because the audience can play mp3s off cd's so I doubt the manufacturer saw any point in adding an aux input.
There are a couple of kits on the market which allow you to connect to the autochanger input of Skoda head units and use that for an aux input but the audience has a built-in changer so there's not likely to be an autochanger input either.
Not sure what you are getting at with regard to the OEM external amp though. If you know someone in Skoda you could probably get one for a reasonable price, otherwise expect to pay a heavily.
Also, the uprated sound system that uses the amp adds 4 extra speakers onto the standard installation. I think it's a mid range speaker in each door below the door handle. You'd have to get new door trims with these speaker mountings in them too or do a neat custom install to make it look good. Don't expect the amp to be able to run subs either. It just wouldn't have the power.
Your major headache will be the wiring looms. I doubt your loom is setup to support the amp or extra speakers.
Sorry to be the bringer of bad tidings.
I'm sure Lummox will be along in a while. He'll clear things up for you because i'm largely speculating!
I checked the audience player and there is an aux connector and in players menu there is possibility to activate it...... also i was thinking the original amplifier because the audience player can remote adjust the off that amplifier so that you don
Sounds different from the UK model. Uprated audio in UK model gives 12 speakers. Your system gives 11 including the sub. I haven't heard of a Skoda sub before either!
Sorry my mistake, yes it was 12 speakers and skoda original sub.....but i don
Have you seen one of these subs? Where does it go in the car?
Seems that they are mented to assembly on spare tire, so if you remove the tools over the tire or remove tools and tire so you can assembly the sub on there or one more place for that is in estate model in side of back room.....where is warning triangle and in that case you have to build some kind of plate whre to assembly it....
