Creaky handbrake
Hi all
Have noticed in mine that the handbrake creaks quite loudly when moved up/down.
Seems to be the rubber cover/gaiter thing (the bit that keeps the hole covered above/below the handbrake) rubbing on the centre console. It's a rubbery trim-on-trim noise.
Will probably just try squirting some silicone spray in there, but wondered if anyone else has had this, and found a simple fix ?
Cheers...
A few people have had the slider jam, so worth giving it a spray with some silicone lubricant.
Ah right didn't know that, will see if I can dig out the spray tonight. Thanks.
