Urgent Help Needed Please - Brake Pads for 312mm Set Up
Hi Guys,
Need your advice, I ordered some EBC Yellow Stuuf Pads for my Car with my brakes currently being 288mm...
These are the ones I ordered but I can still change my order as I placed the order yesterday:
http://www.larkspeed.com/index.pl?p=909DP41517R&a=i
These are the ones I think I need:
http://www.larkspeed.com/index.pl?p=751DP41330R&a=i
I then bought a set of 312mm Brakes from Octy MK1 and I wondered is these pads will fit the 312mm or do I need to order the different ones and if so can you please send me the EBC Part number or linky... :)
Any help much apprieciated. Matty
1st ones look wrong on both counts.
I don't think they are correct for standard 288 brakes or for 312s
the second ones you've linked to look correct though.
the part code is the same if you look up an Leon Cupra or mk1 TT all of which used 312mm brakes
Hi Guys,
EBC Yellow Stuff Pads for MK1 Octy vRS
Front - DP41330R
Rear - DP4680R
Thanks a lot...Glad I asked... :whew:
These are the ones I have fitted on my Mk1 Octy vRS
Front - DP41330R
Rear - DP4680R
I bought 312mm Brake Set Up for my fabia and wnated to buy correct pads for these...
Just orderded the DP41330R
Thanks a lot for your help... :thumbup:
Pretty sure this thread can be closed now... :yes:
You can close it yourself ;)
Guest
