16" Spider Issue
It appears I have an air leak possibly through the rim ... is there any other way to sort this other than replacing the rim ?
If the rim isnt cracked and the tyre is okay (no nails) then it will either be a leaking valve or corroded rim
A corroded rim isnt the end of the world. You can grind off the corrosion and apply a sealing compound around the rim and it will be grand
My local tyre place usually charge a fiver or tenner to do this
They grind the rim around the tyre sealing edge so once the tyre is on you would never know
I've had it in to the tyre place here ... as I originally thought it was a puncture and they said they had sealed it etc. now 8 weeks later its doing exactly the same.
Id try another tyre place
Or stick the spare on and get the alloy shotblasted and powdercoated for £50-70 by an alloy wheel refurb place.
No more air leaks and nice new wheel
2 birds 1 stone
Edited by BigJase88
