Apache VirtualHosts question
Trying to run two basic websites from a machine on my network. Installed Apache 2 (2.0.54) on a WinXP machine (yes yes I know it's only proper Apache when run on a *nix box, but I really don't have the time!)
I have a static IP from my ISP and both domains are pointed to that from my domain registrar. Could it be a problem with this setup? Both domains have simple frames-based web forwarding? Or some DNS-based problem? Anyway, below is the text I've entered in the config file with regards Virtual Hosts:
# Ensure that Apache listens on port 80
Listen 80
# Listen for virtual host requests on all IP addresses
NameVirtualHost *:80
DocumentRoot /htdocs/abc
ServerName www.abc.co.uk
# Other directives here
DocumentRoot /htdocs/def
ServerName www.def.co.uk
The store directory name match the domain name as in the example above, except I've obviously changed swapped my real domains for pretend ones here.
At the moment, when I goto both domains, they display the start page from the second VirtualHost :confused: I was under the impression that it read the first VirtualHost entry in the event of any problem?
I'm a bit stumped TBH, and would appreciate any help. A copy of a HTTPD file with VirtualHosts working would be greatly appreciated :thumbup:
Steve
If you want to give up on the nerdy webserver I can talk you through getting IIS working with host headers :D
:rofl: that was my fallback position!
If I don't get any takers, I'll throw IIS on and see if I can get that working :D:rolleyes:
Steve
Drop the :80 bit, it's not needed.
Apart from that it looks ok. Have you set up the permissions on both directories too?
Options -Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
Allow from all
AllowOverride All
Order allow,deny
Allow from all
