Bit of a rattle at idle - stops when i press the clutch?
Hi all,
Pretty much what the title says, at idle, i get a bit of a rattle that stops when i depress the clutch pedal, anyone come across this before?
Is the clutch on the way out, or something worse!!
D
Dual mass flywheel is goosed probably.
Might just be the clutch release bearing?
Gaz
Clutch release bearing - will make a noise at idle and go away when you press the clutch
Dual mass fly - will rattle (can change tone when clutch is pressed) and can rattle on start up and when you turn the ignition off if you dont have your clutch depressed
One of these is probably your culprit lol
