egr and low voltage fault codes
hi, as above, i have 2 fualt codes currently illuminating the EML. the codes  get are 18009 & 19586. i tried cleaning the egr valve however this hasn't worked, when the valve was off it was quite difficult to press the valve open, however i could do this by hand. does anyone know from this description if this is stiff? if not i am assuming my issue may be the vaccum pipes or the vaccum box module (don't know the name sorry) any help is much apreciated.
Regards, Callum.
