Speaker wiring on a UK 56 plate Octavia
I want to change the factory speakers on my Octavia for some after market ones, my drivers door speaker has four wires going into a plug that plugs into the speaker, I need to know which wire is which and which ones to use please, my new speakers only have two terminals on them, a positive and a negative.
Thanks in advance
I seem to recall that two go up to the tweeter.
It doesn't seem to have any tweeters fitted, I assume that they would be above the door handle beside the control for the remote mirrors?
That's where they are in my car.
Great, thanks. Don't suppose you happen to know which is which do you?
I have two blue and two brown, one of them has a white stripe running the length of the wire, would this one be the positive one?
thats exactly where they are. If they are not there then they are missing and not that they weren't fitted.
If you put a multi meter on the cables you can tell if you are measuring the correct way round because if you have the multimeter + on the negative it will show a minus symbol
Thanks guy's, I'll check it out as soon as I can can
  • 1 year later...
:giggle:
