Adjusting Handbrake
Morning,
Does anyone know if its a hard job to adjust the handbrake on a Monte Carlo? Mine is feeling a little loose and requires a few clicks getting adjusted and doesn't hold as well anymore. A local dealers wants to charge 30 minutes labour to adjust this as its over 1 year old and not covered under warranty.
Is it a hard job, do the wheels and drums needs removed? Any advice would be appreciated.
Thanks,
Stuart.
Thank you very much.
Do you think it may just be a case of adjusting my handbrake cable? I assume this is under the centre console as you state. Is this a easy thing to get off?
Cheers.
Edited by Guest
Stu-Fan
Start at the Drum First.
If you clean the brakes whilst your there, use Brake Cleaner Only, it comes in a spray can.
When adjusting the brake don't Over adjust..
Ok cool, thank you very much.
