Car won't star?!
Hi all,
My car is skoda octavia 2011 1.6L,
I drove my car to work ,every thing going well ,after 6  hours later,when I started the car,it's doen't start(cranking but no engine start).
After that warning lights come up in instrument cluster
1-Traction Control System(TCS)
2-Control system for Exhaust.
I checked the vechicle status in dashboard,I found one error TCS
I removed the negative cable of the battery for one hour ,and connected again without any result
I checked all fuses in engine Bay and all fuses in driver panel all seens OK.
Also changed the battery with good working one with any results.
I checked the car with Vag com,Engine control can't be reached
and checked Auto trans, ABS and can gateway all points to one error
01314 - Engine Control Module
            004 - No Signal/Communication
Friday,23,May,2014,01:22:16:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
                Address 19: CAN Gateway       Labels: 7N0-907-530-V2.clb
Control Module Part Number: 7N0 907 530 C    HW: 1K0 907 951
  Component and/or Version: J533  Gateway H37 0614
           Software Coding: 351302
            Work Shop Code: WSC 73430 790 00088
                      VCID: 306B14F3D8E3
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 19889 km
                    Time Indication: 0
                    Date: 2096.14.26
                    Time: 23:44:14
____________________________________________________________________
Friday,23,May,2014,14:59:12:10074
                Address 02: Auto Trans       Labels: 09G-927-750.lbl
Control Module Part Number: 09G 927 750 JA    HW: 09G 927 750 JA
  Component and/or Version: AQ 250 6F           1368
           Software Coding: 0008520
                      VCID: 79FDE9D74B19
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 19889 km
                    Time Indication: 0
                    Date: 2096.14.26
                    Time: 23:44:14
_______________________________________________________________________________
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.lbl
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0105
   Revision: 00H35001
   Coding: 0001281
   Shop #: WSC 73430 790 00088
   VCID: 7BF1F3DF4125
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 19889 km
                    Time Indication: 0
                    Date: 2096.14.26
                    Time: 23:44:14
I did auto scan for the car by VCDS,Here is the scan and cleared all codes without any result
here is auto scan after deleting all fault codes
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
   Part No SW: 09G 927 750 JA    HW: 09G 927 750 JA
   Component: AQ 250 6F           1368
   Revision: 00H94000    Serial number:
   Coding: 0008520
   VCID: 79FDE9D74B19
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 19889 km
                    Time Indication: 0
                    Date: 2096.14.26
                    Time: 23:44:14
   Revision: 00H35001
   Coding: 0001281
   VCID: 7BF1F3DF4125
1 Fault Found:
Address 02: DTCs cleared
Address 03: DTCs cleared
any Ideas How to solve the problem will be appreciated
At a quick glance I'm going to say low battery voltage given all the canbus communication errors.
if that scan result is after you removed the battery then those faults relate to the battery being disconnected.
clear all those faults and try again, and see what returns.
Thank you for replying...I am already replaced the battery with good working order battery with no result...
I am also log into measuring block 125 which belongs to canbus communication, I find ECU 0(offline),ABS,Airbag and instrument 1(online)
may be something in power circuit of ECU or Shoot ECU or something in Control system for Exhaust making ECU fail to start!!!!
Thank you for your interest
I cleared fault many times...
This error comes back quickly
in Auto trans, ABS,Cent. Elect. and can modules...Engine module missing..
 Hi there,
May i have probably taken out a fuse and put it back in the wrong slot. can you give me  Fuse locations diagram for engine and dash panel.
I am saying that because I am restting the car by pulling out negative terminal for 40 minutes, i notice the  Control system for Exhaust warning light come back after 5 seconds...
I mean control unit checkings components for starting engine ,when it finds error ,it's goes offline.
I am surprising that no ignition fuse in engine fuse panel ,Is that normal?!!!
Waiting for you
  • 6 months later...
Hi Joe,
Did you find out what's wrong with your car? As I'm having a similar problem with mine, but it's intermittent.
