Rubbing Strips
Just wondering if the bump/rubbing strips along the doors are just stick on or if they have clips (ie holes) to hold hem on as well?
thanx :D
No clips holes, just stick on.
If you want to remove pull them off and you have the fun task of getting the double sided tape residue. A toffee wheel is the best thing for this and what the pro's use but something like tar and glue remover and a good polishing work.
Just remmeber the paint may well be a different colour under the rubbing strips if your car is more than a year or so old.
I used boiling water straight from the kettle to pour onto my rear badges (to heat the glue up) when i removed them yesterday - i'm gonna do the side strips as well as soon as i get the door handles painted (looks cleaner if you see Joshes pics) :)
Pour the water onto the strips and use string to cut through the glue using the sawing method, this wont scratch the paint
Don't remove them anyway. I have so many little marks in the rubbing strips but not a single dent in the door from careless ****s opening their doors into my car. If you take them off, your panels will get dented. Rubbing strips look better than dents IMO :thumbup:
Had mine off for months now, 20 mins with a hairdryer and a rag. No dents from parking as of yet (touch wood) and I much prefer the look.
Hardly any glue left on once you heat them first and any left on was totally gone after a couple of normal washes.
So sure I like it, I cant even remember where I put the strips ;)
Are there no holes in the rear when the v/rs badges are removed ?
no...
but there are 2 in the skoda badge...
i copied off Josh :) - removed all badges then restuck the VRS badge in the centre (where the round badge was) to cover the holes - looks 100% better
:D:thumbup: Not too hard to get off - patience, thats all.
