Guesstimate BHP
If I install a autotech induction, Autotech HPFP,then stage 1 map,what BHP 'should' I be looking at?
+ What would the difference be if a 3"DP + Decat make to the stage 1 if I didn't put it on till after? Any significant difference?
Sent from my HTC One_M8 using Tapatalk
+ New 'D' Divertor valve to hold boost
Quite possibly a question better asked in the Fabia section ;)
I presume you have a Tfsi if your using an Autotech HPFP. The Uprated HPFP won't give any difference at stage 1 as your fuel pressure requirement is always being met. Somewhere between 235-250bhp.
If you added a 3" DP it wouldn't make a lot of difference with a stage 1 map, but if you had it mapped to stage 2+ you'll be around 280bhp and a lot more torque, plus you'll be making use of the Uprated HPFP as it'll be requesting 130bar of fuel pressure instead of 109bar.
