Air-Con
Hiya all,
5 year old Fabia 1.4mpi, and the air-con has started working intermittantly. How much should this cost to fix ? Is it just a case of re-charging it ?
Ive got an MOT due, and the garage offer a 'free' air con check, but I know its faulty, so just wonder what the likely damage is ?
Cheers.
RBW.
been told its about 400 quid inc labour the sensor is only about 30quid but the dash has to come out:( im dreding the day mine goes, but its all working fine! 5years old to:)
Leon
You need to get it on a diagnostic rig as mine went and it was the "Evaporator Temp Sensor" which is 30 quid to replace, but requires about 4 hours labour to remove the dash and fit (although Lummox may be able to do it quicker ;)). If the air con hasn't been regassed in 5 years, then it may just be a simple case of getting it regassed (about 50/60 quid), but prob best to get it checked on the diag machine first to rule out faults in the system :D
Chris
15 mins, dash stays where it is ;)
What a man !!! Who needs the 'Stig' :cool:
My air con is playing up too, so, just in case I have to replace the sensor .....got any tips for replacing it?
I'm thinking location and connectors and best way to approach it.
My air con is playing up too' date=' so, just in case I have to replace the sensor .....got any tips for replacing it?
I'm thinking location and connectors and best way to approach it.[/quote']
IIRC from when mine was done, the sensor sits under the dash between the windscreen and the instrument pod. Connector wise I think it's pretty straight forward and just plugs in place.... I'm not sure Ross will want to share his patented 15 minute technique ;)
Chris
IIRC from when mine was done' date=' the sensor sits under the dash between the windscreen and the instrument pod. Connector wise I think it's pretty straight forward and just plugs in place.... I'm not sure Ross will want to share his patented 15 minute technique ;)
Chris[/quote']
oh drivers side then, good job I asked, I thought it was on the passenger side :)
I havent had to do one in ages now but if i do i'll piece together a how to.
