help please - where do i start
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 K    HW: 028 101 223 7
   Component: R4 1,9L EDC G000SG  7002
   Revision: 12345678    Serial number: SKZ7Z0E2968456
   Coding: 0000071
   Shop #: WSC 01286 386 08256
   VCID: 2B55E1278AF0EB46111-807E
3 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault     ( L - **** - needs sorting - poss glowplug or poss loom ? )
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 70.8 Nm
                    Speed: 0.0 km/h
                    Load: 2.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101100
                    Temperature: 6.3°C
                    Bin. Bits: 10110000
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 000 - Signal too High  ( L - **** - needs sorting )
             Freeze Frame:
                    RPM: 714 /min
                    Torque: 139.1 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.32 V  ?? should it not be 5v ? short circuit ?
                    Temperature: 133.2°C
                    Temperature: 10.8°C
                    Temperature: 11.7°C
17075 - Fan 1 Control Circuit  - ( climate panel ??  )
            P0691 - 000 - Short to GND   ( L - **** - needs sorting but where do i start )
             Freeze Frame:
                    RPM: 1890 /min
                    Torque: 109.8 Nm
                    Speed: 87.0 km/h
                    Load: 40.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Temperature: 82.8°C
                    Duty Cycle: 9.6 %
Readiness: 1 1 0 0 1
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus  - ( not important  ?? )
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 246
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000042
   Shop #: WSC 73430 790 00000
   VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent   - new stalk ??
Is there actually a problem with the car?
My first thought is to reset them and see which, if any, come back.
reset and all come back
aircon doesnt work - and engine light on dash
Appears fans at front of engine don't operate :-(
Edited by Tim_davies-moss
as far as i can work out.. air intake flap motor possibly faulty ??
where is it so i can check
