Yeti Windscreen Washer Jet Adjustment
I get two fan shaped jets of screenwash about quarter of the way up the front windscreen.
The rear screen washer fires a single vertical jet that washes the vehicle behind.
I used to stick a pin in a spherical jet and push or pull it until the required effect was obtained,
with my other cars, on this one I cannot even see the little tinkers.
And the rear one can be adjusted with a pin.
Thank you both, I assume the adjusting screw is reached from under the bonnet?
