air intake temp sensor >>
I believe you will find it is item B in the second picture, if you have an engine code, I will confirm for you.
Thank you...
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 000 - Signal too High
             Freeze Frame:
                    RPM: 714 /min
                    Torque: 139.1 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.32 V
                    Temperature: 133.2°C
                    Temperature: 10.8°C
                    Temperature: 11.7°C
Sorry, I should have been more specific, the engine code I need is a 3 letter code usually on a sticker on the spare wheel well. It will be something like AGR, ALH or something else.
BKC - engine code
GQQ - transmition code
As I thought, it is the wiring connector nearest the vacuum canister fitted to the solid boost pipe in picture B.
Hope it helps,
Phil.
perfect
much appreciated pal
