Wheel spacers
Can you fit spacers to a standard VRS estate with 16's (205/55/16)
I'm not going to buy new wheels or change any of the suspension (apart from RARB). I want to keep the car stealth and wide if possible.
Is this a strange idea lol?
Wheel spacers are not great in my experience. They sometimes create centering difficulties at best, and horrendous wheel vibration at worst.
Plus, and probably of most concern - they place a huge additional stress on the wheel stub axes and bearings which they were never designed to take. This could cause a premature failure, or worse a loss of control if something breaks or fails whilst you are driving.
I would have a think before going down this route - although obviously this is just my opinion ;)
Nice one. Good info there. How else could I get stockier look?
Ha cheers. As I said - it's just my opinion...I am sure many others will come on and say they've never had a problem running spacers. But in engineering terms, I've explained the possible pitfalls.
The only way to get a wider track, safely, without stressing the running gear components, is to buy new custom-made wheels, with a different offset.
This helps - but even with this option, there is still additional stress on the suspension.
Can I respectfully ask - why are you set on trying to obtain such an idea, on an estate too? Any particular reason?
I just want to retain the standard look but interested if this setup can have a wider stance. Standard spiders wheels to fill the arches more without going to the expense of wheels and new tyres. I would rather spend any small budget on making it go a little faster.
  • Sponsor
As long as you stick with good quality hubcentric spacers you shouldn't have any problems.
Damian @ DPM Performance
Unless they are H&R ha ha as they are all on holiday lol
Some hubcentric spacers will be fine
Some 15mm front and 20 rears will look good
Great stuff. How do I class the good from the bad? Price £40+ for a pair at the lower end of quality?
Do you stock these things?
Cheers again.
  • Sponsor
We do yes, what sizes were you looking for?
What would you recommend for stock wheels? 15 --> 20?
  • Sponsor
Is the car lowered and what look are you going for? Subtle or all out width?
totally stock, not lowered. Might be a stupid thing to do on stock. What you reckon?
Just looking for wheels to fill out a bit.
  • Sponsor
No not at all, I'd say maybe 10mm front and 15mm rear, could even go further if you wanted but a lot is down to personal choice and how you want them to sit yourself.
