Please help me m2 VRS running problem
It's revs up to 1600rpm then drops then back up
Please help
Please help
Try to give a bit more detail to the problem. Does the engine idle OK, has any work been done to the car recently etc.
It idles fine just revs up then drops few second then back up
Been to garage and one folt code. Pressure in turbo they said but it drives fine just when stoped
Knackered PCV, do a search, very common fault. It's well documented on other VAG forums.
+1 for PCV, easy and cheap to change.
