voltage on maxidot?
Is it possible to enable via vcds the ability to view the battery voltage in maxidot?
I don't think so.
You can however read the system voltage with VCDS.
Only on a Mk3.
Cheers guys.
We had it running to compare my volt meter, looks like the volt meter is poorly thank god
This function on the mk3 is naff, I've had mine show 0% charge after being parked for 8 hours, nothing left switched on and guess what.... It started straight away.
Not via VCDS but with extra module called Polar FIS+, yes.;)
It will show battery voltage and lot of extra parameters of a car.
And even gives you a secret menu option of enabling and adapting sime functions of a car for what you would need VCDS instead.
Take a look here, seems that now the price is very reduced (it was arround 280 Eur...
http://www.movitelonline.com/b2c/producto/AUTO-POLAR-FIS-INTERFACE/2/polar-fis-advanced-pf03-interface-black-kessy-2014-
