Hi, Need a massive fmic for your fab pd130, take a look at this link for information.
You could always get the hoses from samco/ allards
Best wishes
John
Will it fit OK? :confused: Don't like that damage either. :(
I imagine if it works OK and someone isn't too fussed how it looks, it would be a good upgrade on the cheap. :cool:
I know the lad who's selling it and he is the type to replace it just because it doesn't look right even though you can't see it. I'd have no worries about buying from him, if it turns out to be faulty he would sort the problem I'm sure.
I know it been mentioned before. Think Star Performance know the answer. How easy hard it is to fit. Can you use the Cupra piping? What do you need to do/cut to make it fit? Think I read somewhere a problem is with the crash bar.
Was with mine too. ;) Angle grinder soon sorted out that little issue - hack a little bit off here, little bit there, and it was fine. Should say this wasn't for a PD160 FMIC though.
Just have to make up 2 brackets to hang it, then as Jason says take an angle grinder to the bumper bar. Then cut some plastic out off the inner wheel arch liner.
