creation motorsport boost hoses poor fit 4 inches removed off one hose
I decided to start fitting my creation motorsport turbo boost hose kit yesterday i had to cut inches off some of the hoses to fit properly,the main intercooler to inlet mani i cut 4 inches off so be prepared to cut most of the hoses if you decide to buy this kit , for the price though compaired to forge i cant really complane i just thought they would go straight on how wrong was i .
Normal with them and the forge one need trimming
The only one that doesn't is the samco one as I had it mad identical to oem ;-)
very good value for money i just didnt expect to cut so much all seem fine now fitted.
Yep most hoses need trimming. CR Motorsport are the worst though. Although apart from that not badly made. The turbo hose those is quite small width on those if I recall compared to the forge and other variants.
Could be sfs turbo hose.
Mine has crushed.
Pikey fix while we chase up warranty.
Bloody hell. Squashed by the coolant hard pipes?
Mine has crushed.
How the hell? It looks squashed the wrong way to be the water pipe? Is this the oversized sfs tip? I've had mine on about a month now I knew it was tight fit but that takes the biscuit
No coolant pipe sits almost on the bend.
The material has become very soft. If I squash any part it holds that shape instead of springing back.
Yea it is the oversize tip.
Mine was one of the first so I hope they have improved now.
