Indicator/Cruise control stalk
Just a question, is the right stalk for a 2006 MK2 octavia 1K0 953 513 A
And am I right in thinking you just need to add the stalk then enable it's functions via VCDS?=
Depends on what steering controller you have.
Any advise on how to work that out mate?
I have a issue with my indicator stalk, so thought I may as well get cruise at the same time if possible
VCDS scan.
So no way of telling before I buy the stalk without doing a scan first?
And is that a yes to if I fit the correct stalk VCDS will enable cruise?
You could dismantle the steering column and visually check the steering controller.
If the controller is compatible then yes, fit the new stalk and code with VCDS and away you go.
Thanks mike
