VCDS coding in Newcastle upon Tyne
Hi,
Anyone that could help with coding a new yeti to show nav instructions on maxidot display?
I'm in Newcastle on Tyne.
Edited by Woodmaster
There is a guy local to me in Peterlee that has VCDS etc, not too far a drive for you.
But I would have thought there would be someone closer that could help.
I've got one, in Low Fell. Any good to you?
Do you know the correct coding and values to change for it?
Thanks for the replies. Low Fell is great, I'm in Gosforth so no distance.
Think I know the codes. This is from another post on the forum:
No 37
19 can gateway ticked on installation list .
However although navigation was appearing on the maxidot, it would not save the change.
However persistence w on over. Closer examination in the following section revealed that it was showing that no sound system was installed even though the Columbus was working perfectly. Changing the below to skoda sound system allowed the the display in the maxidot to retain the setting and all works fine.
No 37 navigation coding 07.
Long coding helper bit 0-7
Was showing 00 sound system not installed
Changed to 02 skoda sound system can display
Does this make sense?
Thanks for helping,
Stephen
