Octavia key ignition problem
Hi. My key suddenly doesn't fit into the ignition barrel of my 5th late Octavia. Like it's the wrong key. So car won't start. Battery ran out on key after 7 years so been using the spare (previously unused) for a fortnight. Is this connected to the problem? Thanks.
Hello. I had this problem also. There a small dust cover in the barrel which retracts when the key is inserted. This got stuck on my car and I had to a screw driver with a fair bit of force to get it to ping back open. It maybe that is the issue?
Hi. Many thanks. Since seen similar comments and advice elsewhere so will give it a go.thanks again. Chris
