Anyone fitted a Bolero into Yeti CR-S?
I'm looking to upgrade the standard stereo in the Yeti and have found a Bolero from a 2010 Octavian. My question is will it be a straight forward swop or will I need connection adapters etc?
Thanks in advance.
I went bolero to a Columbus and it was a doddle to do, needed to get the correct facia as the Columbus is smaller than the bolero.
Do you actually have the bolero to hand? It should be pretty obvious if you look at them both.
Thanks, I've not purchased it yet but if it's a straight swap then I'll get it :)
Be careful with the Octavia Bolero, there are two styles, one has a facia that is compatible with the Yeti, the other does not an will not fit.
My old Bolero is sat in a box doing nothing, you are welcome to come and take a look (I'm south Manc).
I didnt get the code when I took it out mine so i doubt it'd actually work without getting it unlocked.
Hi mrchrispy, what model / age skoda did it come out of?
The one I was getting came out of a 2010 Octavia VRS, will that fit?
mine is from my 59 plate 140 elegance (yeti obviously :-))
Just replayed to DM, thanks for the offer :)
