Fabia II Monte VCDS Adaptation confusion
Hi guys,
I have had VCDS on my 2012 1.6 Diesel Monte today...
I turned on the needle sweep (pointless I know, but makes me smile) and also the teardrop wipe and anti hijack function
I have seen a lot of people mention about turn lights... Is this possible? as far as I am aware mine just has standard fog lights fighted.
So I guess my question is...
Can anyone definitively say whether:
A) turn lights can be activated with the hardware I have onboard
and
B) Is there anyway I can activate a Coming Home light function (I do not have auto headlights or xenons. just plain old halogens)
Thanks for the help guys.
Jon
Post up full scan from your car and we can advise better.
Some Fabia’s can have cornering lights activated, but others will need a controller update.
Gizmo,
Thanks so much for the reply. What full scan do you want? Im relatively new to VCDS (i.e. I can follow a step by step guide) but I don't quite understand all the lingo yet.
Sorry for being such a newbie!
Jon
when you scan the car save a copy of it then paste the whole scan up on here
Ok I will go do it now! Thanks
do you mean this?
Sunday,24,August,2014,11:16:48:62939
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 5J - Skoda Fabia II
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBFL25J8D3023***
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LN    HW: 03L 906 023 LK
   Component: 1,6l R4 CR td H33 9597
   Revision: --H33---    Serial number:
   Coding: 00114016000500080000
   Shop #: WSC 13765 031 00049
   ASAM Dataset: EV_ECM16TDI02103L 003007
   ROD: N/A
   VCID: 7DF11F7FEC04B5F04BD
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS.lbl
   Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 400100DB006F00B5022C00E300D100000000
   Shop #: WSC 13765 790 00049
   VCID: 4E9388B31D22FE68E27
Address 08: Auto HVAC (J301)       Labels: 6Q0-820-045.lbl
   Part No SW: 5J0 820 045 D    HW: 5J0 820 045 D
   Component: Man AC        H02 0202
   Revision: 0004SH02
   VCID: 264310135112D6287A7
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
   Component: PQ25 BCM      H28 0555
   Revision: -1------    Serial number: --------------
   Coding: 3D980B3808C9240092200E003C6B98C80000400F60000000020000000000
   VCID: 4E9388B31922FE68E27
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3211
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor       03   03 1211
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05  H05 1501
   Subsystem 5 - Part No: 5J0 951 172
1 Fault Found:
03429 - Activation of Right Adaptive Light
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00111010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 48537 km
                    Time Indication: 0
                    Date: 2024.14.19
                    Time: 12:51:00
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagT2C H10 0020
   Revision: --------    Serial number: 003GX01AAU2J
   Coding: 003243
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250_SK25.rod
   VCID: 4A9B84A3ED4AD248BEF
   Crash sensor for side airbag; driver side:
   Serial number: 3495RRB400I4UHC4II84
   Crash sensor for side airbag; passenger side:
   Serial number: 3505RRB401C4UFMUDOV6
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5J0 920 911 D    HW: 5J0 920 911 D
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 420A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 29591B2F480CF950575
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R7 937 087 M
   Component: GW-K-CAN TP20 H28 0555
   Revision: -1------
   Coding: 032300
   VCID: F0EFB64B2356489850B
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SK25.rod
   VCID: EADBA4230D8AB2481EF
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
   Component: Radio-SWING   004 0003
   Revision: -----07S    Serial number: SKZ4Z2M1271461
   Coding: 010004000006
   VCID: 23450907222023001D9
End   ---------------------------------------------------------------------
Log-TMBFL25J8D3023710.txt
Edited by Gizmo68
Just a note - it says a fault on the right adaptive light...
I did start clicking on turning on anything that said anything to do with turning lights.. I have no turned it all back to standard... but dont know if it registered a fault
Yes thats what we need (I have removed the last 3 digits of your Vin No.)
The important bit is:
Part No: HW: 6R7 937 087 M
Now we need someone with cornering lights on a Fabia to confirm their controller part No.
Clear the fault code and see if it returns, it may just be because there was a fault in the circuit
Ok cool thanks! I will post a question up on the fabia section :)
Also it said "clear DTC's" or something to that effect after I had completed the scan. Is that the fault code clearing? I didn't click it as I wasnt sure what it did.
Jon
Edited by Whitey779
damn. no joy
