On/off boost Vrs
Hi all, my brother just bought an Octy vrs 05 plate,205k on the clock, one owner from new. It has a few problems;
On/off boost in all gears under full throttle, I read could be N75 valve?
Also has a few faults codes;
16396 (p0012) bank1, camshaft advance
Specification not reached
16795 (p0411) secondary air injection system
Incorrect flow recognised
Sporadic fault
17748 (p1340) camshaft position/crankshaft position sensor
Incorrect assignment
18010 (p1602) voltage supply terminal 30
Voltage too low
Sporadic fault
Help/ideas anyone?
hey buddy
I had similar problems with jumpy acceleration for good while. was told to check a lot of stuff like MAF,boost leak/busted airline or change the DV.
Eventually bought a new N75 and hey presto
NOt sure about the fault codes but I had to have a tensioner arm replaced and think i had a similar code or two to your bro
Okay cool, thanks for your reply and help :-)
I would be looking towards the timing possible the belt might have jumped a tooth?
P1602 and P0411 wont cause problems that hes having
Thanks for the reply :-) Im from Birmingham, would you happen to know any garages that can check this, as the local garages wouldn't have a clue lol
