Skoda Octavia VRS PD 2007 - dpf
Hi Everyone,
I am looking for some help.
I have a 2007 Skoda Octavia VRS PD Diesel , 60k on the clock.
Recently had a full service a few days a go I was driving home on and the dpf light came on, since then I now have the following lights on.
MIL on
DPF Light on but not flashing
Pre Glow plug light flashing
Differential Pressure sensor is a Malaysian one not US.
My mate has scanned the car (latest snap on kit ) it and it comes up with the following error.
Particulate trap bank1 : Efficiency Below Threshold
DPF is not blocked as we tried a forced regen but it came up not needed as it was not blocked
I have unplugged all of the sensors one by one which show a fault when unplugged only one not showing up a fault seems to the lamba sensor do we think it should show a fault up when unplugged.
Edited by zxindy
If one of the sensors has failed then the advice not to perform a forced regen due to it not needing one may not be true.
If you have the EML, DPF and glowplug lights on then you should also be in limp-home mode.
How long did it take to see the EML and glowplug lights after the initial DPF light appeared?
If I was a betting man I'd be looking to replace the G450 sensor, although given it has the Malaysian type fitted on an 07 suggests it's already had one before...
See my thread "DPF Light on" you have the same car as me and I had codes like that recently.
Went into limp mode a couple of days later after dpf light came on. Ill take a look at the other post I am leaning towards the G450 sensor as well.
Fitted a new G450 sensor , MIL is off but still wont rev over 3k plus the coil light is still flashing, and dpf light is on solid.
After scanning it again it came up with
Oxygen lamba sensor
P2237 Pump Current open circuit
Cleared codes and its not coming up with that anymore only the P2002 Fault.
Could be lamba sensor gone down.
Can you now do a forced regen?
will it do a forced regen if it wont rev over 3k
It won't rev over 3,000RPM because it is in limp-home mode.
I'm not sure what the process for a forced regen is using VCDS, but now you've replaced the sensor the DPF needs to perform a regen.
The car won't regen by itself if in limp-home mode. This is normally the prompt to get it into a dealer for a forced regen.
This sounds like what I had. I entered the log-on through the engine coding for enable service regen , drove for 3-4 miles and everything cleared.
Will give it a try tonight my mate is going to re scan with snap on kit and do a forced regen.
How did you get on ?
