Coding Dash Pod Lights with VagCOM on Mk2 Octy vRS
Hi Guys,
Can you with the aid of VagCOM code the dash pod illumination to be on permantly with ignition?
At the moment it only seems to light up with sidelights.
Steve
it can't be done with vcds
it can be done with other tools that can read the eeprom, which then needs to be modified
Care to eloborate?
Was sure you could light up the needles with VagCOM, but unsure of rest of clocks etc
Edited by beeftech
You can't do it with vcds
I enable illuminated needles on a pre-facelift cluster for a member on here when I coded in the maxidot
Eddie is correct - you need to buy a mk3 as it can be done on that :-p
