gearbox
could someone please tell me the oil type and quantity required for my 2007 vrs 6 speed manual ?
I changed mine a few months ago,best to use genuine oil,part number is:- G052171A2 & you will need to buy 3 litres as the gearbox takes approx 2.3 litres.
The oil level is higher than the filler hole so you need to fill it with a 10mm hosee through the reverse sensor hole or park nose upward on a steep slope.
For those of you with a 1.8tsi or 2.0FSI (non-turbo) fill is only 1.9L.
No its not.........wasnt on mine anyway,i measured the quantity i drained out & put the same back in & it just started to run out of the level/filler hole.
thanks alot ! :happy:
