BorgWarner KO4 kit with Atp manifold
Hai my aim is to get 250hp , please let me know following parts enough ?
Borgwarner KO4 turbo
ATP Manifold
Milltek full exhaust system
Aluminum side mount intercooler
K&N tycoon intake
Forge DV and TIP
Do I need to change the injectors , fuel pump , fuel presure regulator 4 bar ? Or just the above parts ?
Custom code stage 2 remap also
KO3 K280 hybrid will run...er...280 brake with way less work involved!
You'll need a proper single pass fmic though ;-)
I had a borg warner k04-001 on my mk2 golf
Blew the first up at about 24psi odd grrrr idiots
But it held well and moved that golf :)
APR actually do a kit for a ko4-001 for 245/250
Awesome gti list it
In India, does your Octavia come with a K03S from the factory? If so, 250bhp is achievable if everything else is working correctly.
I think from another thread on here with a member from india that they are fitted with the AUM engine. Not that it will make any difference to tuning.
K03s will do 250 bhp no need for all that crap IMO
Go fmic not side mount there crap
My Vrs is with headlight washer and xenon type so fitting fmic is a big problem , otherwise
I have do like rob did
What about BBT k250 ?
Does it work with forge smic and stage 2 map !
http://www.beachbugg.../k250-124-p.asp
They will all work with a SMIC but youll be limited on how much power you can make due to the heat and in india it will be even worse
No way will you achieve power without proper cooling. Especially in India's climate.
It be better to go for a bigger framed turbo and achieve power with less pressure. But 1.8t not really suitable
Looked into water/meth?
