Knock Sensor 1 (G61) Problem
Hi Guys,
I have problem in my 1.6 BSE engine.
Following error occurs:
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 HA
Component: SIMOS71 1.6l 2VG 1039
Revision: --H04--- Serial number: XXXXXXXXXXXX
Coding: 0004071
Shop #: WSC 73430 790 00000
VCID: 65C5B5A7D7A1
1 Fault Found:
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 007 - Short to Ground - Intermittent
Freeze Frame:
RPM: 3136 /min
Mass Air / Rev.: 376.1 mg/str
Ign. Timing: 0.4 °ATDC
Voltage: 0.180 V
RPM: 3040 /min
Voltage: 0.180 V
Readiness: 0000 0000
Sometimes the engine works irregular (Irregular rpm), and that’s all, no power loss or something like that .
Circuit  short to ground means that something’s wrong with sensor ? Or is a  symptom that the sensor detects unusual vibration?
Should I start which replacing G61? Wirings looks ok for me.
