Has my MAF packed in on my Octavia vRS? (Video inside)
Col200sx
Typically when a MAF fails , unplugging it actually makes car run better.
The error you have now
17705 Pressure drop between turbo and throttle valve P1297 (check dv)
Could be either:
DV
N75 Valve
Boost leak / split hose
Old DV should not be cleaned with anything but thrown in the bin.
The new style OEM DV has a better diaphragm and stronger made. It is the best leak free DV available, so i would recommended getting new one if you have never replaced it.
These cars are getting on a bit now so converting hoses and pipes over to silicon or getting oem is worthwhile. :thumbup:
Thanks for the detailed answer. I have no documentation that the dump valve has ever been replaced. The cars is now at 142k miles.
Will I only know if the dump valve was the cause by replacing it with another one? Are there any tell-tale signs that it's the probem?
(haven't taken off a dump valve before so not sure what to look for).
