Skoda Octavia mk1 clutch bearing, SM flywheel, handbrake lever, alternator belt tensioner
Marselus
Hi having a clear out and this is what i have found that is not needed.
Sachs clutch release bearing brand new never been fitted in car just tried on clutch release fork. £25
Single mass flywheel removed from Skoda Octavia 1.9 TDi ALH 2005 with about 62000 miles on the clock. I have bought it as i was about to convert mi clutch to SM flywheel but ended up fitting new dual mass flywheel clutch kit. There for  this is now not required any more. It was degreased and them sprayed with thin layer of oil to prevent corrosion and the packed in polythene bag.  £35
Alternator belt tensioner with damper. Removed from mi car as i have thought that it is making rattling noise but it was the belt that needed to be changed so now i have new in car and this one (still in good working order) is not required any more. £30
Hand brake lever handle. Removed from mi car and replaced by VRS handle so this one is not needed any more. £10
Gearbox knob-gaiter-surrounding, I have replaced mine with VRS knob and gaiter but the surrounding did have broken clips on so i left original surroundings. It can be still used if you glue it somehow into the car or fix it somehow. £10
All prices are with postage within UK via 2nd class apart from the flywheel this is too heavy and will prefer collection but can investigate postage costs if necessary.
post-75214-0-35625800-1410883494_thumb.jpgpost-75214-0-85984400-1410883510_thumb.jpgpost-75214-0-21873700-1410883522_thumb.jpgpost-75214-0-50810400-1410883531_thumb.jpgpost-75214-0-60404000-1410883549_thumb.jpgpost-75214-0-51082100-1410883568_thumb.jpgpost-75214-0-91225300-1410883586_thumb.jpgpost-75214-0-28957600-1410883598_thumb.jpgpost-75214-0-78238400-1410883627_thumb.jpgpost-75214-0-46350700-1410883639_thumb.jpgpost-75214-0-37439300-1410883649_thumb.jpg
