1.2 and 1.4 gearbox swap? Are they compatible
Hey guys,
Skoda newbie here
My gearbox has just collapsed on my 2003 Skoda Fabia (Blueline?). I have a 2003 1.4 skoda fabia and was wondering if anyone knows whether they are interchangeable.
Also, are skodas known for gearbox issues at all?
Thanks everyone,
Eddie
I'm thinking of going to ebay if i don't have luck or going to the local salvage. I was hoping it would fit but with a difference gearing ratio :(
looking at ebay m8 1.2 and 1.4 are different most prob the ratios whats your engine code i'll find 1 cheap as poss for u
I might have one going free! depends what your engine code is
I can't view it at the moment, as its at the yard! Could i let you know tomorrow night if possible, please?
Of course mate
Of course mate
Appreciate it a lot. Do you know the engine number off the top of your head so i know what to look for tomorrow, and where abouts is it situated?
thanks again
thanks mate, i'll let you know tomorrow if thats alright
thanks again
Look under the boot carpet and there is a white sticker with it all printed on!
Brilliant thanks! Do you have any info on the gearbox you have?
Will check code but it's still fitted to an engine so I'd have to remove it but came off a 1.2 6v Fabia which had an electrical issue and had done 100000 miles roughly
1.2 engine will be one of the following codes...
AWY
BMD
AZQ
BME
I'll have a look tomorrow and let you know. It is a 12v if that will really matter, i'm not sure though. i appreciate your time bro, it means a lot
AWY
BMD
AZQ
BME
ah i see, is the code only 3 letters then?
Also, if i know the engine code, will i be able to find out which gearbox exactly will fit my skoda or do i need to go deeper than that?
cheers
12 valve is AZQ or BME
Yes, only three letters.
Gearbox code is on same sticker in boot.
Ah perfect. Thanks for your help man. I'll get all the info down tomorrow and i'll progress from there
Cool :)
Here's a pic of my sticker if it helps you know what you're looking for. My Fabia is a 1.4 but the sticker will be the same. In my case the gearbox is FNK and the engine AQW.
Oh cool, that makes it easier. i would have totally overlooked that!
So am i correct in presuming all gearboxes under the same code will fit my car?
Spot on :)
Yes :)
Yes :)
cool. Anyway, thanks again for your help. I'll give it a seeing to tomorrow and hopefully i can get somewhere from there!  :D
