Which gearbox oil?
I've decided to change the oil in the gearbox of my 2.0PD 4x4. ( not Haldex clutch) Are there any good oils recommended for this or should I stick with VAG oil?
had mine done a while back, general consensus is to use genuine VAG stuff,not cheap thou!
As above use vag stuff is the best advise
++ on the VAG recommendation.
Some internals, eg the cages which hold the ball bearings may be susceptable to certain additives.  Get it wrong and you can have a pile of scrap
Try using TPS as this may cost less than a main dealer.
