Bulbs for Rear Lights on Combi.
I would be grateful if anyone could help me with the right bulb types to order for the rear light unit in a combi, as I am trying to replace all bulbs with canbus error free bulbs if possible.   thanks for any help.
W5W/T10 bulbs in the front and rear overhead cabin lights, and also for the lights built into the inside of the estate boot lid.
Get a bag of 10 of these: http://pages.ebay.com/link/?nav=item.view&alt=web&id=131275460556
And a bag of 10 of these: http://pages.ebay.com/link/?nav=item.view&alt=web&id=130976781942
You'll then be able to also do the side mirror puddle lights, the under/door puddle lights, and the front sidelights (matches the xenons on the pre-FL).
One lot is white-white, and the other is warm-white.
Edited by JakeBlade
It's the bulb sizes in the rear light cluster that I am look for , parking light, brake light , indicator, and fog light,   thanks,  all other lights are already replaced,
Canbus error free bulbs? Can you tell me in English what this is about?!
error free, means that you should not get the bulb fault warning, when using these bulbs, as the led's are lower power.
Here you go, taken from the osram app. Let us know which LEDs you choose, and how you get on with them.
Brand.: SKODA
Model: SUPERB Estate (3T5)
Type: 2.0 TDI 16V
Function: Back-up lamp
Product Family: ORIGINAL LINE
Order no.: 921
ECE Category: W16W
Techn. Data 12V 16W W2,1x9,5d
Function: License plate light
Order no.: 6418
ECE Category: C5W
Techn. Data 12V 5W SV8,5 (11x35)
Function: Rear direction indicator
Order no.: 5009
ECE Category: RY10W
Techn. Data 12V 10W BAU15s
Function: Rear fog lamp
Order no.: 7506
ECE Category: P21W
Techn. Data 12V 21W BA15s
Function: Stop lamp
Order no.: 921
ECE Category: W16W
Function: Tail light
Order no.: 2825
ECE Category: W5W
Techn. Data 12V 5W W2,1x9,5d
The non-LED rear clusters on the Superb are designed to work with normal incandescent bulbs. This is why they have curved reflective lenses behind the bulbs - optimised for non-LED bulbs.
LED's are very directional so you lose the reflective benefits offered by non-LED bulbs.
This means that retrofitting LED's into the rear clusters will reduce not improve light output.
You'd be better upgrading to the facelft combi rear clusters which are already LED.
Jake and Silver, thanks for the help,   something to think about,  difference in cost of changing bulbs or complete units is approx €280 more for the new units, and then the cost of bulbs for this unit.
Since the lights are coloured by the light covers already, and the efficiency benefit is negligible compared to the overall efficiency of the car, it doesn't make much sense to worry about changing rear light bulbs at all. All you get is a faster turn-on time and possibly longer bulb life, though cost per hour may still be higher.
Converting the front lights to LED so they match the Xenons is a nice upgrade though - it's not going to happen on my car till next year though. Also upgrading the floodlights in the boot door so the boot opening is illuminated better at night would be genuinely useful. those bulbs aren't on the CANbus at all (I took one out to have a look and the car didn't give a bulb error at all), so anything that'll fit and takes 12V will work there.
